rhagfo
May 30, 2016Explorer III
MFL wrote:
Don't know what FW you have, but the disconnect switch should kill most everything inside. A few emergency things, such as LP/Co detector, emergency weather radio may still work.
If actual battery cable is disconnected, nothing will work.
Above assumes you are not plugged into shore power.
Jerry
The purpose in my mine is to kill ALL 12 volt power, I installed my own and that is exactly what it does. If I were to check latest RV building regulations, likely the break away brake switch should always have power. I could easly fix that, but because I need on to run the landing gear, I have turning it on covered.
It for sure disconnect all parasitic draws CO2 and propane detectors as they are what will draw the battery down over time.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
