fj12ryder
May 30, 2016Explorer III
My experience is that the factory "Battery Disconnect Switch" varies from unit to unit. Mine shuts down most 12 volt but not the CO detector or the smoke alarm. The slides will still work as will the stabilizers. If you want to shut down all 12 volt to the trailer you need to install your own real Battery Disconnect Switch at the battery.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
