SailingOn
May 30, 2016Explorer
If you're hooked to 120V shore power then
even with the battery disconnected the converter will supply 12V and everything will run.
lakeside013104 wrote:
When my switch is pulled, everything works as normal. The wire leads are connected to both terminals of the switch. Maybe I have a bad switch?
Lakeside
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
