jdrocci's avatar
jdrocci
Battery Disconnect Solenoid Fuse
2005 Holiday Rambler Ambassador 40PLQ
Under the driver seat on the outside is a compartment with a box that contains the battery disconnect solenoid. This solenoid has a nominal 5A fuse in the actuator circuit. Several times, I've lost all DC power to the house and found the cause to be this fuse. The last time it happened, I replaced the fuse with a 10A unit. Yesterday, with the MH parked in my driveway on shore power and the AC running, I locked up the unit and went inside my residence for the evening. This morning when I opened the MH for the day, I found all 12VDC circuits dead and the solenoid fuse blown again, This seems to have happened with no known stimulus.
Is this kind of failure well-known and if so, how/why does it happen?
Joe
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 30, 2026
