beaubeau's avatar
beaubeau
Battery drain + solar
I have a small travel trailer and I keep it stored several miles away in a storage lot.
When I drop it off, I turn all the breakers off and turn all the lights and fridge off, but every time I go to pick it up, the battery is dead.
What could be causing that? The smoke detectors? CO2 detector? But I think they are just 9V battery powered.
Also, I was wondering how to calculate how much of a solar charger I would need to keep my battery topped off enough to be able to leave the fridge on.
Any thoughts?
Thanks.
  • On top of the other advice given, typical RV refrigerators will run on electric (120VAC) or propane. When they're running on propane they will still need a certain amount of 12v power (battery). There are models that will also use just 12v battery power, but they're pretty rare in a travel trailer.
    As already mentioned, a 100 watt solar system would be more than enough to maintain your battery without the need to unplug things or shut off breakers.
  • Things likely to be using dc (battery) power in storage
    CO (not CO2) detector
    LPG detector
    smoke detector
    Some of the above may have their own battery instead.
  • beaubeau wrote:
    I was thinking that maybe the DC-to-AC convertor was being used to power something AC, from the battery, so I throw all the breakers..
    DC to AC is an inverter. If that's what you have, then just keeping the inverter on will drain power. Disconnect the cable.
  • For the effort I would go 80 to 100 watts minimum for solar.
    I assume you are running the fridge on propane.
    In the mean time charge the battery 48 hours and remove a cable when stored without power.
  • The breakers ... I was thinking that maybe the DC-to-AC convertor was being used to power something AC, from the battery, so I throw all the breakers.
    I see what you mean about propane, I think. If I didn't have enough battery power then it would go into gas mode?
    Thanks for the help.
  • Breakers have nothing to do with battery power.. that's all fuses. The best thing to do is remove a battery cable.
    A small 100w panel should do it, but you'll also have to worry about running out of propane.
