TheWanderer's avatar
TheWanderer
Battery drain issues!
Hey everyone!
Been a while since I posted last but I am happy to say after having the transmission replaced on my motorhome she has been running well for me and I am back on the road!
I have ran into a bit of an issue recently though with my house battery I am hoping y'all can help me investigate.
Generally the battery seems to behave as it should. Takes a charge fine while driving or running my generator, and charges to 2.6-2.8v. Generally I can charge my phone on that, run lights, a small 12v fan overnight, and thats about it before recharging the next day around 12-12.2v.
I am not currently using my fridge nor furnace so they should not be causing much or any draw.
There has been a couple mornings however where I have woken up to a terrible voltage reading of only about 10v! ??
It happened a week ago or so and I was worried my battery might be bad, but after charging it that time it seemed to work correctly for a week without overdischarging until last night. Woke up this morning and another 10v reading. Double-checked at the battery with voltmeter and confirmed at 10.5v.
What could be causing such a drastic difference or drain randomly like that?
My suspisions are either bad battery (i sure hope not), bad ground possibly, or some other drain/connection issue.
Thanks in advance for any advice you can give. :)
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 17, 2025
