Benaroo's avatar
Benaroo
Battery draining fast and converter running hard
Brand new Evergreen IGO C183RB travel trailer, the company is out of business a couple of weeks after my purchase.
Trailer was sent to service center because it was constantly tripping the campground GFCI whenever it was plugged into GFCI shore power. (they said the problem was a bad 30amp plug but that they had to disconnect all the white wires in the panel to find it)
Got the trailer back less than 2 days ago, and went out to look at it this morning. It was not plugged in since I got it back. I have a Tri-Metric digital battery monitor in the trailer and it said that the batteries were at 56 percent discharge level. Before the service, the batteries were always at 98 percent or more discharge level.
As soon as I plugged into my house 120 power, the converter came on and the converter fan was running really hard and continuously. The converter is also drawing 22amps with nothing on in the trailer. NO lights, no A/C ... nothing at all.
I've had the trailer plugged in for 3 hours now, and the battery is only at 62 versus the 56 percent it was at. Called the RV service center and they tell me its likely that the converter is blown and needs replacement. The unit has only been used for 2 weekends since getting it. I checked all the fuses in the panel and can't find any that are blown.
Is it possible that the service center's electrical work, has messed up something, or do I just have a bad converter and need to get it replaced? Bringing in the trailer again tomorrow, but don't have a lot of confidence in these folks. They're the only option in my area though so any advice would be greatly appreciated.
  • Check with your voltmeter in a number of places.
    First with nothing connected, at the battery.
    Then connected to the truck, you should see truck battery voltage.
    Then connected to shore power, you should see converter output voltage.
    Then most important, check at the converter output terminals both positive and negative.
    If you converter is putting out, but the battery is low, likely you have a loose wire between the battery and converter. That is what I found with the same situation, I wiggled the wires at the converter terminal strip, and suddenly the interior lights got much brighter and I had found my problem. It was the negative wire at the converter that was loose, so I tightened it up and all was good again.
  • Check the break away switch. Also make sure the battery isn't internally shorted (or hooked up backwards for that matter) by checkin gits voltage. If it's down around 10V it's junk. I bought a brand new battery that was bad a couple of years ago. Store said it happens!
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
