KendallP
Apr 28, 2014Explorer
NinerBikes wrote:
Let battery sit for a day. Take your hydrometer and read the specific gravity of every cell of each battery. Log the results. You should see 1.270 t 1.280 specific gravity for every cell.
Yes. Temp adjusted, this is about right.
However...
If your battery has permanently hardened sulfate, you might get a lower reading, but yet your equalizing efforts have yielded all they're going to. And this is good to know. If you don't dry camp much, then you might be fine with 1.250 or something. Or... after employing my equalizing methods you find you're in "the white" range of the hydrometer, you may decide they're better used for their core-charge rebate.
Oh... also... be sure your electrolyte levels are up where they should be first. When full and resting, there still should be some gap between the top of the fluid and the top of the battery. This should leave room for heat expansion during equalizing.
If you're levels are a little low, but still above the plates, it might be a little safer to hold off on adding water 'til after your equalization work because that expansion is going to cause those levels to rise.
However, once you add water, you need to stir them again with an equalizing charge to remove stratification.
Also, that Rears and Sore-Butt charger of Niner's may be just the ticket.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
