westend
May 24, 2014Explorer
Isn't that the same HF charger Mex put his seal of disapproval on?
If you're charging and equalizing the 6V's separately, you'll need a voltage of 7->8 volts and 10 amps wouldn't be too much.
If you're charging the 6V's in series connection (12V), you'll need a voltage of 15->16 volts and 10amps.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
