Wayne_Dohnal
Jul 08, 2013Explorer
That fuse/ should be AT LEAST 30a if not higher. Most are resettable.But is the wiring heavy enough to go past 20 amps? To determine the correct fuse size, you must know what the make and model of the converter is, and what gauge wiring is used between the converter and the battery.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
