Almot
May 11, 2014Explorer III
Yes, load cable is separate, and there is a voltage sense wire in Rogue, but you connect the loads wire in parallel to the controller wire. Usually - on the bus near controller. When controller is raising the voltage to compensate for drop, the load wire and all the appliances are getting this raised voltage - not the "correct" voltage that is on the battery terminals.
The only way to avoid mistreating your appliances while dealing with too high voltage drop is to connect the loads cable directly to the battery.
Edit:
My bad. Voltage drop calculators are to be used with "one-way" distance. Yes, <2% drop with AWG 6.
Now, with converter pumping 60A through the same cable - this is how I see it. Converter has no voltage sense, so there will be uncompensated drop and lower voltages on terminals. Your 12V devices are safe then, but charging will be under-volted. Though with converter it is always undervolted, with those long #8 wires from converter to battery. I wouldn't trust my WFCO with anything but floating charge.
Edit:
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
