- 2oldmanExplorer IIIt's worse for the concrete floor than the battery when acid spills on it. But somehow this old advice just never dies, like cats smothering babies.
- wa8yxmExplorer III3 answwes.
1 a FULLY CHARGED battery is good all winter in MI.. However if the battery is just sitting there. even disconnected physically, it will loose charge (Self discharge) over time.. So you need to keep a tender on it.
2: If your RV has a good quality 3-stage converter.. Plugging in will "tend" the battery
3: If you disconnect and bring into the house/garage (where you have power for the tender) BEFORE you unhook take two small cans of spray paint, One red, one black, Spray the wires hooked to the POSITIVE terminal RED.. Black on the negative
If more than one wire is hooked to either Red or Black, tape or tie them together (String or zip tie) one for red one for black.
Insulate the RED wires (Wrap with plastic wrap or tape) - owenssailorExplorerI keep my trailer batteries safe over the winter by taking them South in the trailer.
My boat batteries get to stay home here in Ontario where it gets very cold. For the last 30+ years I have charged them in Nov, disconnected them and checked them in Apr. No problems.
I know one guy who had a trickle charger on his boat batteries. The power cord got disconnected and the charger became a load that ran his batteries down. Two of them split spilling the electrolyte into the bilge. Bad.
Also - the concrete myth is a left over from batteries from the 1940's 1950' or earlier. It does not apply anymore. - babockExplorer
John&Joey wrote:
Its actually not a best practice anymore. Probably actually better to have it on a cold concrete floor. It will discharge less since it is cooler.
I don't doubt you, but at $70 to $90 a piece I'll stick with best practices. Was nice you were going to store his battery on your concrete floor for him though - free_radicalExplorer
joesann wrote:
Just picked up our new 5th wheel. Was wondering what to do with the battery for the winter? Should I remove the battery from the coach and keep inside till spring? Thanks for your responce
I leave my battery in the TC,,have 80W solar panel that keeps it charged up all winter..just have to clean snow off it..no problems yet - SidecarFlipExplorer III
John&Joey wrote:
SidecarFlip wrote:
Not that I find it true or false but the old wives tale about setting a battery on concrete went out with hard rubber battery cases. The new plastic cased batteries don't seem to mind at all.
Mine ate all on concrete and I've never had an issue.
Actually, I it would have been on a heated concrete floor (my shop has PEX in floor heat) and on a tender. I keep them all on Tenders actually. Bike batteries, welder batteries, truck batteries and lawnmower batteries... - MEXICOWANDERERExplorer
Charged until full then utterly disconnected, batteries do the hibernation snore very well. Cold temps mean minimum self discharge and minimum activity of the battery acid gnawing on the plates. At -20F plate erosion is about a third that at 50F
The only thing to watch for is a smart charger out-stipiding itself and declaring the battery charged at 70% state of charge.
Definition of "Disconnected" either battery terminal with zero wires connected to it. - LwiddisExplorer II“Trust me taking them out and bringing them inside your house is the way to go”
Why, Rock, if you can keep them charged? 85 percent charged freezes at minus 67 degrees F. See http://www.trojanbattery.com/pdf/WP_DeepCycleBatteryStorage_0512.pdf TRUST ME! - John_JoeyExplorer
I don't doubt you, but at $70 to $90 a piece I'll stick with best practices. Was nice you were going to store his battery on your concrete floor for him though - SidecarFlipExplorer IIINot that I find it true or false but the old wives tale about setting a battery on concrete went out with hard rubber battery cases. The new plastic cased batteries don't seem to mind at all.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
