Old-Biscuit
Nov 24, 2020Explorer III
SteveKlobe wrote:
Thank you all. RV is on shore power for the winter so should remain fully charged by trickle. Winter is mild here in TN with a few periods of below freezing for a few days, but well above 0.
Sounds like we'll be ok leaving them in. Thank you all for your feedback.
Did you find where the batteries are?
Should check water levels at least monthly when staying connected to Shore Power.....then if water levels good you can go longer intervolves between checking water levels
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
