I do not like ads for
"PLUGGER-IN AND LETTER RIP" chargers, tenders, or other energy sources.
ZERO numbers except "FOUR AMPS OUTPUT!" Buying blind.
"HERE! BUY THIS HERE BATTERY! IT'S PERFECT FOR YOUR R.V.! CONNECT THE CABLES AND GO!" Full color picture of the battery - a red headed man, blonde wife, two dark headed children all standing around their RV showing 118 teeth. numbers? What numbers except for C.C.A.
I've been sucker-punched enough in my life buying stuff whose ads screech FANTASTIC! UNBELIEVABLE, SIX STAGE CHARGING, NEVER GETS DULL, JUST READ READER COMMENTS BELOW! Then along came LED chips and I had to learn how to send questions to the manufacturer to prevent being defrauded there. FIND AN LED FIXTURE AD that lists milliamps required @ 12-volts. Then you've found a responsible company.
I do not need atomic LASER clock accuracy. But neither do I need an overhyped watch that tells high and low tide, phases of the moon and loses 4-minutes a day.
