What I use for my small inventory of loose 12V batteries is a stand-alone shop charger and then tend them on a 12V (nominal) wall wart with two alligator clips. The wallwart has a no load output of 750 ma at 15VDC. When first connected to battery the charge voltage lowers to the batteries existing voltage. I monitor the voltage rise until it attains 14V, usually a period of several days. I then, disconnect the wallwart and connect it to the next battery. This regimen is repeated a few times a year to keep the batteries top charged. I should also be doing an equalizing process but that more often gets skipped when dealing with these castoffs. I use these batteries in my lawn equipment and for emergency pump use at the house.
