Have 4, 6 volts batteries . Can I use 2 battery maintainers one for 2 6 volters , the other hook to the other 6 volt pair. Will that be good for alright to do?
Monitoring the voltage float point. One point to consider is to disconnect the battery bank from any possibility of an unexpected load. 500ma per 6 cells is plenty enough potential. If your area of storage is subject to temperature extremes insure the float voltage is appropriate.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
