Have 4, 6 volts batteries . Can I use 2 battery maintainers one for 2 6 volters , the other hook to the other 6 volt pair. Will that be good for alright to do?
You have 4 , 6 volt batteries set up to operate as 2, 12 v batteries. Use one maintainer with the positive hooked to positive pair A and the negative to negative pair B. I ran mine in this manner off of a BT Jr which is a .75 A maintainer. Come in off the road, turn off the manual disconnect and plug in the maintainer. The maintainer will usually be in maintenance mode by the following morning. Randy Bergen
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
