Gjac
Jan 30, 2016Explorer III
Check the simple things first. What does the battery read when converter is plugged in? Should be 13+ v what is the output of the converter? Should be 14+ v. Do you have a battery cut off switch or battery disconnect? Is power getting to the switch? Is it getting through the switch when on? If you post back you will get more accurate help.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
