Almot
Jan 30, 2016Explorer III
truepath wrote:
I think that either the power switch is not sending power to the converter, the converter is not functioning or there is some kind of continuity break in the wire from the converter to the battery. Suggestions on how to go about isolating the problem would be appreciated.
Yes :)
Seriously though, what suggestions do you expect? It's either converter output, or converter-battery wiring. So go ahead and check both. (The "wiring" would include any fuses and switches btw converter and battery). Disconnect the battery and see if there is 13-14V output on converter terminals, with shore power on.
Could also be wiring btw the shore input and converter, but, since 120V gets through, I would suspect things downstream.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
