time2roll
Mar 17, 2021Nomad
Yes leave a couple lights on. If you discharge extremely slow you may count more amp/hrs compared to when you are actually using the RV. The small draw you post is virtually at rest so the battery scale of voltage is a bit different. Such as 12.06 might be 50% in normal usage but would be only 25% charge in your virtual rest experiment.
The 12 Volt Side of Life
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
