starcraft69's avatar
starcraft69
Battery post / cables
Is it a big deal to use 3/8 lugs on 5/16 battery post? I am doing a 4x6v GC battery install with 4/0 wire and have 3/8 lugs.
  • No. What counts is the contact area around the bottom of the threaded post that the lug is to sit on. Some are wide and flat and others are sort of not so flat, reducing contact area.
    If the latter, you can use a copper flat washer so the lug will be tight when bolted down. Not ideal, but what else can you do?
    Ring lugs are also either lumpy or flat. flat is better than lumpy for contact area. Stacking lumpy ring lugs is a loser. Avoid stacking where possible by using a buss bar.
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Dec 02, 2025
