CODan
Jun 27, 2021Explorer
battery questions and issues
new RV owner here - 2000 Tioga 24', had it thoroughly checked on and repaired when we got it, then it sat for 2 years unusued. Now I'm trying to get systems going.
Batteries were brand new 2 years ago.
When I parked it I pulled the 2 6V batteries (which were wired in series) and put one of the batteries on a trickle charger I use for my car and motorcycles. Unfortunately I charged ONE of the 6V batteries at 12 volts for about 12 hours before I discovered my mistake, then switched it to 12V.
Did I ruin this battery?
I correctly charged the other battery at 6V.
The batteries check out at 6V each when tested individually, or 12+ volts when wired in series.I took a photo for reference before I disconnected them so I know I got them right.
I've put the batteries back in, wired in series , but have problems when checking things out on 12V.
Everything works perfectly on 120 volts - heater, water pump, lights. But only the lights (LEDs) work when on 12 volts.
The water pump runs on battery (very quietly) but doesn't pump any water. I can't hear any water being moved at all. If I plug into 120 it works perfectly.
And it seems like the voltage goes down VERY quickly.
Any thoughts?
Thank you. I'm not generally dumb (just RVs) so maybe I'll be able to help one day.
Any thoughts?
