ib516's avatar
ib516
Explorer II
Aug 14, 2017
Battery questions
I know there are some very knowledgeable folks on this topic, hoping you'll chime in.
Current set up is a small 17' hybrid that HAD a new (Costco), single group 27 12v (105 AH) battery. I use a 2000w inverter generator to charge it using the on board converter. I also have a 2500w modified sine wave inverter attached for running a 760w coffee maker in the morning before generators are allowed to run (9am to 1030am and 5pm to 7pm ONLY). Well, I completely fried that G27 battery (Costco brand). I neglected to check the water level and had to add about 500-750mL of distilled by the time I thought to check it. Also, the 5 min it took to brew a pot of coffee would basically kill the battery. It would go from 12.3-12.4V down to 11.7-11.6V to brew one pot.
So, I got rid of the G27 12V battery, and need an upgrade.
Here are my options:
  • 2 of the same Costco (but new) G27 12V 105AH batteries that I will be more diligent at checking electrolyte levels
  • 2 12V AGM batteries ($$)
  • 2 Costco 6V golf cart batteries listed as 208AH @ 6V
Which of these would be best?
  • Get the two golf cart batteries. When you had the 11.7 voltage reading was that after or during the inverter use? You should take the reading after the battery has rested for awhile.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
