dpgllg wrote:
Trying to find a way to change the wiring to the slide and whatever else might be drawing current I have decided that since I have a brand new in box Blue Sea Battery disconnect that I purchased to install on my old 5th wheel that I will install this switch directly off the battery cable.
Battery Disconnect
This will eliminate a draw from the battery while stored.
It sure will ... good plan. :B Just keep in mind you need to decide whether to also run the trailer brakes' breakaway system through this switch or whether to wire it directly to the battery. For a number of reasons I chose the former but it does mean I have to ensure the switch is on anytime I tow ... I do, so it's never been an issue but you may want to have this connected all the time so if you do forget your breakaway system will still be functional.
