Gjac wrote:
SoundGuy wrote:
Gjac wrote:
If bad replace with 2 6 volt Golf Cart batteries (wired in series to make 12 volts) from Costco or Sam's Club as enblethen suggested.
SoundGuy wrote:
Why would he do that? :h
Gjac wrote:
I never told the OP to waste his money upgrading his battery ...
There are several reasons to replace with 2 6v GC batteries instead of a 12v marine battery IF his battery is bad even if you don't dry camp often.
Hmmmm ... a contradiction? :
For the OP who "never" dry camps a single G27 or G31 will serve his purposes just fine, as it has my own all the years we've been camping. :B
Where is the contradiction? Was my post not clear? I said nothing about upgrading his battery. I said IF his battery was bad then replace it. IF it is good there is no need to replace it. Op please let us know if you found your problem.
The battery will be placed on a charger later today. Once fully charged I will take it to a local auto parts store to have it tested.
I have the disconnect switch That I will be installing to insure the power is fully cut off. I can not do that until after this Friday when my 5th wheel is pulled out of the underground storage facility.
I will post once the battery is tested
Thanks!
Dave
