MDKMDK
Oct 16, 2019Explorer
I just replaced my dying factory FLA batteries with 2 X 100Ah LiFePO4 units. To do this, I had to disconnect the batteries while the controller was up and running and it was a sunny day. I actually considered pulling the 3 rooftop panel connectors out of the 3 way combiner, but after consulting Winnebago Tech Support, they said no need.
My system is a factory installed Zamp Solar setup, 3 X 100W panels and the ZS-30A PWM controller. When all was reconnected, everything is up and running with no apparent ill effects. So, I'm going to *assume* this charge controller doesn't care if you disconnect the batteries, either at the battery terminals manually, or with an added disconnect switch. Which I didn't add. Never ocurred to me to add one.
Just in case you've got the same, or similar, setup.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
