syperk
Oct 13, 2018Explorer
That 1.35kW is the input power for the microwave - the actual cooking power is only 900W. I've measured the power being used by the microwave when supplied from shore power using a "kill-a-watt" plug, and it never draws more than 1200W. So, I think the 1500W inverter should be fine - as long as the batteries can stay above 10.5V while powering it.
Seems like this should be a fairly common setup so I'd love to hear from someone who has done this in practice. I don't really have space for 4 batteries, but I'm assuming I could draw more amps with two 12V batteries in parallel (compared to two 6V in series). Do AGMs have lower internal resistance?
Thanks!
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
