bigfootford
Jun 11, 2013Nomad II
mojoroo wrote:
The fridge is a Norcold N611RT.
Thanks for telling us the mod #. You may not have an issue with anything in your rig and what you are seeing is just normal or your battery is in trouble.... So use this thread as a drill, learning to use that meter in the DC voltage mode!
According to the owners manual your moisture heater/divider heater is on when the fridge is on.
Norcold N6 N8 owners manual
You should make sure the fridge is off to test the resting voltage of your battery. You must wait 15 min or more to get a good resting voltage reading. You should not be hooked to shore power. There are other "loads" on your battery but we will get into that later if needed.
When on gas or 120vac (shore power) it will be using 12vdc power to operate. The shore power is only used for cooling, All the electronics, fan, lamp and this divider heater runs on 12vdc.
Here is a great website for manuals:
http://www.gasrefrigeration.net/norcold_manuals.htm
Jim
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
