5erToyHauler's avatar
5erToyHauler
Battery SOC Low - Voltage Normal
Hi All.
I'm new here so go easy on me. I've Googled for hours but can't find any solid answers. My setup is in my signature. So here's my issue....
Whether plugged into shore power, running my generator, or charging with my solar setup under the sun on a good day, I can't get my SOC up on my batteries. I'm monitoring my vitals through my display/meter for my solar setup. When we were out boondocking 2 weekends ago, I couldn't seem to get my batteries up past 60%. I could run my generator for many hours. It would only bring them up to the low 60's and than hover there. With the generator running, the SOC would drop when using lots of 12v power. Not by a lot but it would drop. I will note that the converter was working. During the day when the panel was charging at 10-16amps it would bring the SOC up to the 90's. But as soon as the sun disappeared it would drop back down to that 58%-61% range. Here's the kicker, my battery voltage readings seemed to be dead on. Exactly what they were last season when my solar display would show my batteries charging right up to 100% and staying there. There is no abnormal drop in voltage (according to my display) when 12v power is being used. I can't say that I've experienced any noticeable loss in capacity. The furnace ran all through the night. The batteries were drawn down in the morning as per the norm. Than they charge back up to the recent norm of 58%. I can't get them to show past 61% no matter how long the generator runs or the shore power is connected. And again, when the solar panel is going strong it will bring the SOC up into the 90's. But once the sun goes away it will go back down around 58%. My best guess would be that the converter can't get the high SOC readings because of the low amperage it charges at compared to my solar setup. All voltage readings on my display seem to match the numbers I get when taken directly off the batteries using my multimeter. Last night I went and checked out my readings again. The trailer had sat in good sun for a few days with the main battery disconnect off. My display was showing 94% SOC @ 13.0V. When I turned the main power disconnect to "On" It went down to 78% SOC @ 13.0V. There would be next to nothing for load at this point. I turned my kitchen lights on and it went down to 50% @ 12.8V. Shut them off and I went to 58% @ 12.9V. Than I cut the main disconnect and things stayed the same (58% @ 12.9V). SOC never recovered more than that.
So it seems that once a load is applied, the SOC/ Capacity doesn't hold up but the voltage stays where it should. In my research the only situation that I could come up with was that I may have a case of Sulphation. My Solar Charge Controller has multiple stages of charging. It is supposed to equalize when necessary. How it knows when to do so...... I am not sure. If my voltage was dropping and the batteries were draining quickly than it would be an easy diagnosis. But, the fact that the voltage seems to fluctuate on a normal scale while the SOC is all over the place, has me scratching my head. So I'm calling out all experts to see what gives?
Thanks in advance for your help.
Having RV issues? Connect with others who have been in your shoes.24,301 PostsLatest Activity: Aug 16, 2025
