jarata1's avatar
jarata1
Battery terminals question
I need to buy a battery for my rv.
Do I hook it up with a ring terminal and if so what size ring,or do I use a regular terminal connector.
Also where do you buy your batteries and which ones do you buy
  • 2oldman wrote:
    jarata1 wrote:
    The battery in the front of the travel trailer that you use when there is no power at campground
    No, that blue line means to click the link to read about 'what battery?' LOL
    Next time oldman please give constructive advise thank you
  • Usually the positive terminal is marked on the battery case with a +
    And the negative terminal is marked with a -
    The positive terminal needs a 5/16" diameter hole ring terminal
    The negative terminal needs a 1/4" diameter hole ring terminal
    This is for a car size RV battery
  • RoyB's avatar
    RoyB
    Explorer II
    Different batteries will use different sizes I guess.. This is a spec sheet for the popular Trojan T105 battery
    T105 Battery Specs
    RoyKen
  • my trailer came with wires for the battery, they had ring terminals on the ends that fit nicely on a marine deep cycle battery.
    For many years as a youth I thought marine battery meant it had extra threaded terminal for accessories, cuz the boats motor used the big posts for the starter.
  • The battery in the front of the travel trailer that you use when there is no power at campground
Having RV issues? Connect with others who have been in your shoes.24,318 PostsLatest Activity: Sep 14, 2025
