Redterpos3's avatar
Redterpos3
Battery Trojan vs. LIfeline
Ok, i've done my research, measured my area for a 2-battery bank and am looking at these two possibilities:
1) Lifeline - GPL-6CT RV - 2 6-volt AGM batteries - $440.99 + s/h - Total = $1,023.94
2) Trojan - T105-AGM - 2 6-volt AGM - $275 + 27 core - Total = $640
Looks to me like the lifeline would provide a much greater (almost 40% more) battery capacity; while the Trojans are about that much cheaper. Am i thinking right?? What say you?
  • When the 8955 Whiffy was floating at 13.7 I fitted an inline 500-ampere Schottky rectifier to drop voltage three tenths. When the Whiffy smoked and upon autopsy I damaged several ribs laughing, I now use the BORG. But it is going to be replaced by the GigaWatt.
    The 10-amp Whiffy fuse failed. I replaced it. Plugged it in. One of the two bi-polar transistors popped off a chunk the side of two dimes, stacked. The shrapnel pinged off my safety goggles. When I unfastened the heat sink from the corpse I found Whiffy did not use a micro-gram of heat sink compound on the cheap grade Chinese heatsink "counterfeit Berquist Sil Pad" pad. Wiffco may be manufactured in northwest Pakistan or the Hindukush as far as engineering land mines are concerned.
  • I am going to have to switch voltage regulators on my toad when I fit an AGM. The factory ECU voltage regulator is crazy-nuts too high of voltage for an AGM battery that will be subjected to 150+F under-hood temperatures. I am going to do with a remote rheostat (already made up) Transpo 911-02 voltage regulator.
    But again, this is for "far-side-of-the-moon" environment. Celsi is going to construct a 13" tray underhood, and the battery is going to be wrapped in 316 grade marine stainless cable so it doesn't spring out of jail and run down the road. It is amazing how well a 12-volt electric fence charger works when isolated atop rubber tires with a stainless braid ground strap connected to the fence charger opposite post. A key FOB 12-volt remote switches the system.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
