waynefi wrote:
Those are convenient little monitors, but how exactly do you interpret the reading?
I've seen several charts that give voltage for a given SOC, but they don't agree with each other. I've seen voltage for 50% SOC listed as anything from 12.06 up to 12.4.
Those are open circuit voltages, but a wired in meter is likely to be reading with, at a minimum, the fridge, the CO monitor, and probably the standby mode of the TV/stereo drawing power. So what voltage means "time to recharge"?
The biggest difference is one chart is a disconnected battery rested 48 hours and the other chart is a battery in moderate use (up to 25 amps).
Resting 12.24 is 50%
Under load 12.06 is 50% (see 12v side of life)
I primarily use the voltmeter to see my batteries are above 14 volts at some point during the day indicating solar is working enough to get me through to the next day.
Otherwise it is a bit of fuzzy interpretation. Generally if you are less than 12.3 it is a good time to recharge when convenient. Below 12.0 is time to charge right away.
JMHO
