ppine wrote:
Our water has a pH of 7.8.  It has some TDS around 200 ppm.  My batteries last 7 years some longer than that. Get over your fear.
YUP!
The company I work for uses "city" water right out the spigot in all of our forklift batteries.. Used hard and put away wet at the end of the shift which can typically run 10 hrs per day..
I can only recall once when we had a forklift battery replacement in over 20 yrs of constant abuse (discharged to near flat then quick charged overnight for the next day shift)..
Myself, I would not want to use my well water, HEAVY iron solids (looks like red mud), plugs my prefilter often before it gets to my softener system (brine backwash).. Just too much possiblilty of high mineral and salt content in my water.
However, what I do use is simply ANY BOTTLED DRINKING water, yes, they fully remove all minerals and then add back in a touch of minerals for balancing taste, PH levels. Those mineral levels in Bottled drinking water will not substantially harm your batteries..
Allowing air to get to the plates will do more damage than the small amount of minerals in bottled drinking water.
I can easily get 10 yrs of operation out of my GC batts just adding bottled drinking water.
I cannot fathom as to why folks are buying and drinking pure distilled water, that has to taste terrible and it is not good for your body since it will not supply essential minerals in your diet you typically get from regular water.
CAN YOU DRINK DISTILLED WATER
