Ivylog
Nov 12, 2016Explorer III
You should have a 10 amp setting on your meter so disconnect one battery terminal and put it in series and see how many amps you get. Should be around 2 amps and if so, your batteries are no good. If it's closer to 10 then you have something left on... basement lights are often missed. How many amps with the inverter turned off?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
