MEXICOWANDERER
Nov 12, 2016Explorer
- CHECKLIST LIKE THE OP REQUESTED
- Unplug, turn off all loads inside
- Measure battery voltage what does it say?
- Report back
- If voltage says >12.4 you have a batteries themselves problems. Report back
- If the batteries cannot charge to 13+ volts when plugged in check back you have a charger problem
- This is a step-by-step troubleshooting procedure and to try and list all the permutations would make the RV.net server, catch fire
- Take it a step at a time starting with the above.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
