Morninghill
Aug 16, 2017Explorer
Thanks for the clear description of how to provide an earth ground when it's mising. Added to my todo list.
My inverter/charger will handle 60v to 140v so would be an excellent option. However, as wired, if it sees ac input, it passes it through to ac loads as well as converting some to 12v for the charger.
Will check with Magnum to see if its possible to wire it so both the charger and inverter can operate at the same time. If so, will hire it done, way above my pay grade. Would be the ideal solution.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
