FWC wrote:
S Davis wrote:
Itinerant1 wrote:
Look at Lifeblue batteries also and compare $$. They have 100, 200, 300ah batteries and if cold temp is an issue they have batteries with warmers in them.
The one I thing I don’t like about Lifeblue is their max draw is 150 amps continuous and 200 amp for 30 minutes on their 200ah and 300ah batteries. So I would need to have two to run my 2800watt inverter at full draw where Battle Born is 300amps continuous and 500amps surge for 30 seconds on one of their 270ah.
If you are planning on running two in parallel then the max draw adds. So it would be 300A continuous and 400A for 30 minutes wth two Lifeblue in parallel.. That should be more than enough for running your 2800W inverter.
And yes, battleborn is over priced. The price of LiFePO4 cells has plummeted in the last year, yet BB prices have not.
I am planning two banks that can be charged or used independently and would like to be able to power the inverter with just one bank, so I guess going with six 100ah is probably the way I will go as this would give me a max of 300amp draw per bank. Also I could have multiple battery failures and not be dead in the water. It looks like the lifeblue and battle born are about the same price on the 100ah.
