Second Chance wrote:
The table hasn't been updated in a while. It doesn't reflect WFCO's new lithum charger/converter (which I've confirmed with BB is compatible). There may be others that need to be added to the list. The bottom line is this response I got from BB:
Bulk/absorb 14.2 - 14.6 Volts(we usually recommend 14.4)
float 13.6 Volts or lower
No equalization(or set it to 14.4v)
No temperature compensation
Absorption time is 20 minutes per battery(if it is an option).
Rob
Are you sure about the float? Seems like it should be 13.6v or HIGHER, not lower.
