Itinerant1 wrote:
BFL13 wrote:
You might wish to modify your routine based on this advice. It could be that your 99% is not correct. Your displays might not be showing the true picture based on the graphs etc here. You might be overcharging somewhat?
At last some graphs and a way to tell when your Li batt is full!
" Full charge is reached when the current decreases to between 3 and 5 percent of the Ah rating"
https://batteryuniversity.com/learn/article/charging_lithium_ion_batteries
I'm sure you mean well but I'll stick to my routine/ settings.
Stick to what you know best. ;)
Not trying to tell you how to suck eggs. Just want to know more, as do others I suspect.
If you have the time and patience, it would help to understand all this if you explained more how your routine does not contradict the advice in the link.
Also how exactly your displays tell you where you are at wrt the graphs in the battuni link. ( I know you have posted photos of the displayed info before, but it is hard to relate the readings to where things are at on the recharge graphs in that link)
