BFL13 wrote:
You might wish to modify your routine based on this advice. It could be that your 99% is not correct. Your displays might not be showing the true picture based on the graphs etc here. You might be overcharging somewhat?
At last some graphs and a way to tell when your Li batt is full!
" Full charge is reached when the current decreases to between 3 and 5 percent of the Ah rating"
https://batteryuniversity.com/learn/article/charging_lithium_ion_batteries
I don't think you can overcharge, I believe the Battery management system (BMS) protects from over charging, I'm not sure about that though.
I know the BMS protects from voltage getting to low and also protects from low temp .
