@BFL
BFL Wrote
"First you need the battery to be truly full,"
I programmed mine by watching Will Prouses video
He had me run my battery down all of the way and then program
Battleborn websites says...
"There is automatic cell balancing for optimal charge and can be fully discharged without damage.
The BMS prevents over discharge damage"
And so after I ran my battery all of the way down I believe I
zeroed out the amp hour meter and programmed in that i have a 100 amp hour battery and then started charging,
At that point I watched the meter rise until it reached 100ah , I then switch the capacity monitor to % setting and it told me I was at
100% soc
