I think my chart looks pretty close to what the Battleborn company said ,, they said to bulk charge until you get to absorption and then charge another 20 thru 30 minutes .
Well if you look at my chart I hit absorption about 12:04 Am .
If you add about 30 minutes to 12:04 Am you get 12:34 Am
At 12:45Am my amps were tapered down to about 4 amps
So it's only off by about 11 minutes which makes since to err on the safe side.
Companies always err on the safe side
Disregard my soc% readings i think there slightly off .
Also disregard the blue dot , it doesn't mean anything.
Time and tapering amps tell it all.
Also I take temperature readings of the battery all the time while charging using my infra red temp gun , no heat issues.
In a couple days I'll run my battery all the way down and then make a updated better chart when charging them back up.
I'll get my capacity meter dialed in better too.
