BFL
BFL Quote
"One of the selling points of Li is supposed to be that it accepts high amps to a high SOC, unlike Wets and AGMs. Yours is not acting right. No idea why."
You're not impressed with being able to put 53ah back into the battery in one hour ???
Because even if You're correct that bulk should last longer that will just make the battery charge faster yet if there's something wrong and then corrected.
Even more impressive .
I don't worry about the battery charger output being a little low because I'm really only supposed to charge the Battleborn with a maximum of 50 amps for a longer battery life .
I would prefer a 50 amp charger but all I had was a 60 amp charger lay in around , or should I say 55 amp battery charger lay in around.
I'll check my electrical connections and stuff and report back.
