Lots of good questions!
No idea how Itinerant1's monitoring set-up works that shows so many amps still being accepted at 98% SOC. He does still have loads running. A Trimetric only shows amps to the battery, but his system is somehow connected to his BMS, and it is all very peculiar, so he can explain it. Beats me.
He does seem to have 500AH for his battery bank as noted earlier where his % SOC change matches the AHs. It is not clear if that takes any heat loss into account, but is "close enough" seems like.
OK, your monitor can't tell what is going on until first you get the BB battery full, connect the monitor, set up the monitor with the AH size of the bank, and do a cycle.
Now the monitor can measure the AH going down and back up and see how many it took. It should allow for heat loss on the way back up. ( No heat loss discharging)
So without the monitor hooked up, first charge the battery as full as it can get at 14.4v setting on the converter. No loads on the battery either! (You can use the monitor for its ammeter doing this, but ignore anything else it says)
When amps get down to about 4 amps, BB says the battery is full. So if it sits there and stays at 4 amps, then those 4 amps must be going to heat. Watch battery temperature!
With an AGM , now down to its 0.5amps (per 100AH of bank) it is full at that 14.4 too. But if you leave it there, you can see the battery temp still rising. At some point amps will start back up, rising from that low of 0.5 amps. Oops! STOP that. Reduce to 13.6, you are done. (past done--stop earlier before amps start climbing again.)
OK, so what about the BB which is not an AGM? I am guessing here:
Let amps get down to 4 amps. If they go lower, let them go lower. Your battery voltage can't get any higher than 14.4, which is the converter voltage.
By now at the low amps, voltage drop will be small so compare battery voltage with converter voltage. If they are the same 14.4, the battery is full. Once amps stall at some low level, declare that to be as full as that battery can be.
Now, set up the monitor so its AH counter is at zero, set the bank to 100AH (for now) and do a cycle down to say 50%. See what happens.
By setting the monitor to Li, that probably ? sets the heat loss factor (charging efficiency) for the AH count on the run back up during charging. All being well, your AH count should match the % SOC on the way back up, and when the monitor says you are at 100% amps should be what they got down to before when you got to full.
If the monitor's AH count does not match for 100AH of bank, then your 100AH setting was wrong. eg, at 32F it would be more like 85AH, where the 100AH is only for 77F. (assuming Li is like AGMs for that) so you have to allow for that.
If temperature does not account for any mis-match, then your battery might be "aged" so it has lower capacity than when new. You can sort that all out later if need be, once the first set of numbers come in.
I see that Li batts age by loss of lithium. That compares with sulphation of a lead-acid battery and also to shedding of plates.
So expect to adjust your bank AH setting on the monitor to a lower number each year over the years. Also fiddle with it as required at low ambient temperatures if you want any accuracy that day.
Since the charging efficiency the monitor uses can be off a bit, there will be an accumulating error in its AH count when recharging over several cycles. So you have to reset that every so often by getting the battery to true full (never mind what the monitor says) and then start over with the monitor's AH counter reset to zero at true full battery.
