BFL13 wrote:
Well, I find it all very confusing, so it is a good thing I don't have an Li-ion battery.
Way simpler then you think.
I posted a picture after all my text.
In this picture is all that you need to know.
In this picture they talk about the three important things.
I'll try to define them.
1: target voltage is the voltage you set the charger up to , for example my battleborn manufacturer says it needs to be charged at 14.4 volts so I dial my charger to 14.4 volts , they call that the target voltage. That's it , that's how simple!
2: duration of charge source
All this is is the amount of time you charge !
Don't charge past 80% soc
That is it , that's how simple it is!
3: charge rate
Charge rate is just selecting the right amount of amps of a charger!
For example i have a 100 ah battery and so my ideal charge rate charge rate is about a 50 amp charger.
That's it , that's how simple it is.
Them 3 things is all you need to know.
Plus I would add one more thing
Don't drain your battery below 25% soc
In this picture read the very last sentence, they tell you how easy it is to charge Li batteries.
Always keep in mind that the three important things they talk about in this picture is all you need!!!!
There's people that have alot of knowledge about these batteries and they speak alot of technical jargon , they can go way deeper in info then you would ever need.
Alot of people build there own battery and I envy those people but there's a simpler way , the battery manufacture did all the brain work for you.
You can buy a plug in play battery , your done!
Ain't that complicated.
People can complain about price but how many hours are you going to spend online trying to figure out how the inner guts of the battery work.
It takes massive amount of time to learn all that technical sub details.
You could spend that time instead getting a part time job flopping the money down on a ready to go battery .
It's easy
You buy a drop in battery
Wire it up
Use energy
Charge and put energy back into it
repeat.
Follow the three simple things they talk about in the picture and your battery will last a long time
Picture below
