Trackrig
May 25, 2016Explorer II
That's interesting and cheap enough to "Play" with.
In the Amazon description it says: "Loop through sensor multiple times to strengthen signal. For example, if your current signal is only 0.2 Amps, you could loop the wire through the sensor 10 times and the signal would by 10X stronger and would appear as 2.0 Amps."
To make the meter work, you have to disconnect a wire and run it through the sensor. Based on the above quote, if you have sufficient slack in a smaller wire, I wonder if you could fold it over and then stick the fold through the sensor. Since there would be two runs of the wire, you'd then have to divide the reading by two.
Bill
Bill
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
