BFL13
Jan 27, 2014Explorer II
Higher amps won't do you much good unless you can do them at higher voltage.
6 volt batteries need 15+ volts to fully charge them. The usual Rv converter can't do that. I use a VEC1093DBD which can do the 15v if set to Equalize to do the "finish" portion of the recharge as recommended here:
http://www.wholesalesolar.com/pdf.folder/battery-folder/charging_instruction_2011_2.pdf
You can use your converter for the first stages and then swap over to the 1093 to finish it off, or just use the 1093 for the whole thing.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
