BFL13
Jan 29, 2014Explorer II
Note that the PD9280 needs a 20amp circuit to plug into and that it is a power hungry item to run from a generator. There are conflicting reports whether a Honda 2000 can run one.
You might consider the PowerMax 75amper which is power factor corrected instead that can run on a 15amp circuit. However it has a fixed charging profile with no manual override with a charge wizard gizmo if that matters to you.
Also in any case, the converter to battery wiring and the fuse will need changing going up from 55 to 75-80 amps.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
