joelabq
Oct 16, 2015Explorer III
I replaced my Dometic (died in 2 years) with an Atwood. I even had to buy a new control board since I hooked it up wrong and was able to get parts no problem. The unit is much more quiet, the 15k comes with a heat pump too. The fan doesn't turn off (that turns some people off), but goes to such a low speed that it doesn't bother us. Power usage is way better, I can even run it off of a Xantrex Prosine 2000 on my 4 Golf carts for an hour after installing a Hard start cap I had put in the Dometic.
I am not sure how the insides of a Dometic or RVP/Coleman that aren't "builder grade" look, but the Atwood had insulated linesets, the duct insulation appeared much higher quality and better engineered, and it came with two seperate fan motors for the Condensor and blower unlike the Dometic and colemans I've owned/seen.
I did upgrade from a 13.5k btu to a 15k when I bought the Atwood, but I feel it cools better than if I would have just bought a Dometic 15k. No data to back it up though.
Joel
Joel
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
