lc0338
Nov 17, 2016Explorer
as others have mentioned the tanks should not be a problem unless they are full with no expansion room. The only other place of concern is at the waste empty valve. The RV antifreeze is slightly heavier than water so if when you empty your tanks you put a little antifreeze in it will flow down to the waste gate and protect it from damage and the rest should be OK. Actually the more liquid in your tanks the more resistance to freezing however don't let get too full just in case. A gallon of antifreeze in each waste tank put in when empty should be enough until you dump. Just my opinion.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
